S320 Cdi fuel pump. Is this right?
SteveB73
SteveB73
Sussex
S320Long CDi
  • #2
I’ve just replaced seals and was going to refit after removing in near darkness after work earlier this week and noticed the play in the shaft. Is this normal or is it horribly worn?
mersum1es
Finland
SteveB73
SteveB73
Sussex
S320Long CDi
Okay thanks. Not sure if the shaft is machined like that or it’s worn like that. It’s running now and not overly noisy from my limited diesel experience. Best of all it’s mot leaking either. There does seem to be a bit of lateral play from end to end of the hole, but it’s working for now. Only the bottom bolt that’s a total pita if it needs to come off again
mersum1es
Finland
just to clarify, that -o- shape piece is meant to include some tolerance so shafts may have some some misalignment. Because of asymmetric power transfer shaft will then wear on opposite sides in direction of rotating. Bottom bolt is not bad if you remove serpentine belt and fuel lines/clamps.
SteveB73
SteveB73
Sussex
S320Long CDi
Well sadly it is still leaking (in fact worse) after test drive though sadly from a different pump, and the fuel feed hoses seem to be leaking too now. There weren’t any replacement washers for them in the kit unfortunately. Looking at the clamp that holds them firm I think that may also be damaged too. Looks like there should be a sort of finger piece on it that appears broken off.. PITA.
mersum1es
Finland
always change o-rings when replacing anything there... additionally clamp which holds hoses in side of hp-pump has originally a foam like shim under the plate.
Taffy7hfa
Oxford
The fuel supply pipework on the inlet side of the HP pump is not very durable.
om613
london
S202 C250TD, S123 240TD
Those white foam shims... you can't buy them, just what did they do ???
