S320 cdi w221 starts cuts out
creeder
S320 cdi w221
Hi guys I'm new on here would appreciate your help my s320 cdi everytime starts up first time cuts out then will always fire up on second try car runs all day long soon as you turn her off she will do the same again your would be appreciated thankyou
onefortheroad
uk.
Me -2019 GLC 350 coupe AMG line. Mrs- 1.2 vauxhall Corsa 2021 ,orange with a black roof. .
Try 2 ign cycles -5/10 seconds before turning to start . Well known issue is for fuel to leak back to the tank overnight.
C
creeder
S320 cdi w221
Thankyou but it happens after few min of driving
mioba
Nottingham and Köln
You need a garage to check for fuel leaks. Good luck and post back
C
creeder
S320 cdi w221
Update guys camshaft sensor was faulty no fault codes when it got hot it gave me the problem starts now and no cutting out anymore
mersum1es
Finland
first time I heard cam sensor will cut the engine. Crank sensor does, always. Both can prevent it firing.
C
creeder
S320 cdi w221
It always fired up but would cut out after 2 seconds when it heats up yes crank sensor would stop it firing the last thing I'd assume it was a cam sensor it must cut signal to injectors when ecu detects a bad signal
onefortheroad
uk.
You said after a few minutes of driving. Make your mind up .
C
creeder
S320 cdi w221
No need to be cheeky with your comments
I'm here to pass on my experience and what I found out what was the issue with my car your attitude is not appreciated
onefortheroad
uk.
mersum1es
Finland
after 2sec it still might be 'starting mode', when cam sync is observed. After 'run mode' cam data is ignored and crank data controls.
onefortheroad
uk.
Ok Karen.
