I have just ordered an air filter as gauge was red and looked old/partially blocked when removed. Do you think this could be problem, smoky and poor pick up until about 2000 rpm under WOT
Under the inlet maniifold on RHS when looked at from front? Is exhaust gas routed around rear of engine from turbo/exhaust side ie left hand side to the EGR, if not how is it routed?
thanks Richard for the local Indie contact details.
The intercooler is normally just for cooling pressurised inlet air, are you saying that it also cools exhaust gases before passing into the inlet manifold via the EGR valve.
It's difficult to see where the exhaust routing is to the EGR valve
Fresh air and Exhaust gases are both passed through the intercooler and into the EGR.
I's suggest that after you have replaced your air filter, if that does not solve the problem, that you consult an indie as it may be a simple sensor fault causing the mixture to be too rich.
To me, it looks as though the EGR path is from the exhaust manifold straight back into the cylinder head through a channel at the rear of the engine and then out the inlet side of the head into a heat exchanger then into the EGR valve.
So the valve is under your inlet manifold below the raised middle part between the 2 groups of 3 inlet runners. You should see the big hose coming from the intercooler eventually going upwards to meet it, and you should see the heat exchanger bolted in to the side (closest the engine) of the EGR valve.
Located rear engine compartment on intake
• Re-circulates exhaust gases to aid in emission regulations
• Exhaust gases flow through cylinder head to EGR cooler
• EGR Solenoid energized by CDI control unit N3/9
• Hall sensor integrated within EGR read by CDI control unit N3/9, determines EGR
position and adjusts accordingly
• Re-circulated gases via EGR valve enter combustion chamber
Welwyn Merx Limited is a family run business with genuine passion, dedication and 25 years of experience dealing with Mercedes-Benz and AMG passenger cars. Tel: 01707 395999www.welwynmerx.uk
