davidpmiller
- May 16, 2006
Hi, I have had a problem with my S320 for several months now. Initially, I posted regarding possible MAF problems, this has been changed but the problem is still there.
Essentially, there is a shuddering which seems to go from the drivers floorpan right through to the rear of the car. This appears to be more apparent when the car is between either 1000-2000 revs or it can be replicated at 80mph - dropping off the accelerator and then immediately re-applying. It is basically there all the time but to different degrees. Sometimes, quite a bad vibration noice comes from the nearside rear.
I have had it in the garage many times, more recently on Monday - a specialist checked everything under the vehicle as he suspected a worn gearbox mounting. He could not find any problems at all.
I don't really know what to do next - the mechanic has heard the problem and agrees there is an issue but cannot identify the problem. The constant vibration under your feet is just getting annoying now, can anyone offer any suggestions? The car is a March 2003 S320CDI with 60K on the clock.
Any help would be greatly appreciated.
Regards
Regards
