S550 L 2007 , Navigation DVD replacement
alpha
Dubai, UAE
S550 L, 2007
Dear All,
I need your support to find out the location of Navigation DVD in S550, 2007 model, because I need to change the maps currently in my car.
My reverse camera is also not working? is there any fuse the error says
plugb84/3x1 (backup camera connector) is not inserted or the lines for the voltage supply are defective
thanks in advance
For the navigation there is only a disc that comes out annually, the contents are copied to the hard drive, once updated the disc can be sold on as no longer needed.
No fuse for the rear camera, you need to check the connections in the boot hinge area.
AMGeed
Poole, Dorset
S204 C180K
A
alpha
Dubai, UAE
S550 L, 2007
so can anyone tell me how to upload new maps in my merc?
any tutorial available ?
All you do is to put the disc in and follow the instruction, and they are you accept the terms and away it goes, it can take 40 mins and should not be turned off till done, you can drive the car during the update. It really is that simple.
A
alpha
Dubai, UAE
S550 L, 2007
The question is where to put the disk? Are u talking about the front 6 cd changer??
Yes, just insert as disc 1.
