Saddle tank not refilling itself.
Mickey42
IPSWICH, ENGLAND
2005 CLK 320
CLK 320 petrol 2004. I’ve replaced both units in the tank with new and aftermarket fuel filter. Fuel lines have been blown through too yet the driver side of the tank will not fill. I really could do with some advice on this please. Thanks
Doug1234
Bedfordshire uk
1997 w210 e300td
NJS5
Catherington, Hampshire.
2011 R230 SL350, 2016 Discovery 4 Landmark, 1973 MG B GT V8, 1959 MGA roadster.
I think the answer is in post 10 in that thread; which was my first thought:-
Why not fit a small pump, pumping out of one side and into the other?
Re-routing the return to the same side as the fuel feed should have exactly the same effect, but be completely reliable.
Though I can see that some fuel is going to spill over into what used to be the return side (and which now is exclusively supplied by either the fuel filler neck or just the balance pipe) and may get trapped. However it will be trapped on the cold side, so the level in the feed tank will be higher and stop you running out of fuel.
NJSS
