cellutron
- Mar 6, 2013
- Location
- Bournemouth,Dorset,UK
- CDi SE/2003/2.2
- Thread Starter
- Thread starter
- #21
I would say the likelyhood is the high pressure pump is at fault. I had a C220cdi in on tuesday with this exact same fault. If the Low pressure pump is working (driving the vacuum to pull the fuel across) and pulling the fuel to the engine when there is supply then all the other pipework must effectively be ok. It only leaves the high pressure pump as the common denominator which, if the return valve sticks blocks the rest of the system from working.
Steve, there are 2 ports on the lefthand side of high pressure pump; one receives the T-junctioned- pipe= feed from low pressure pump terminated with a stop valve, and the other port is the return path that connects to the solenoid end of the fuel line. I can't remember which goes where when I took out the pumps and pipes for inspection. There seems to be no arrows or any other indications to show in/ out flows. Can you help please? Thanks
