philharve
- Jan 20, 2005
- Age
- 73
- Location
- Falmouth, Cornwall, United Kingdom
- Website
- go.to
- W202 C230K Auto 2000
Hi All
A Mercedes saloon has a least 4 jacking points, including two each side, and usually carries a jack of sufficient strength to be able to raise one corner of the vehicle for the purposes of changing a wheel. But suppose you wish to remove two wheels simultaneously, for example, to perform a front and back wheel swap in order to extend tyre life due to different camber wear on each tyre. Is it better to use a jack at each wheel (two jacks?) or can the vehicle be safely lifted using a powerful hydraulic jack placed midway between the two jacking points? Is the chassis strong enough at this mid point that it would not sustain damage during the lift?
Obviously if the vehicle was taken to a tyre fitting specialist they would use a hoist that would support the vehicle from beneath so that all 4 wheels are lifted off the ground simultaneously. These hoists are equipped with at least 4 rubber-faced, independently adjustable arms that can be placed near the side jacking points. This arrangement would permit tyre rotation, if required.
However, if such a hoist was unavailable, is it possible to safely lift one side of the vehicle without using the standard jacking points?
I can imagine a couple of axle stands or two towers of study wooden blocks would easily be able to support the weight of the vehicle and prevent it from crashing down if the hydraulic jack were to fail. Safety is paramount.
I have seen vehicles lifted using the cross members, front and back, when working on the front or rear of the vehicle but I am not entirely happy that this is a safe lifting procedure even though the cross members are very strong.
Regards
Phil
Regards
Phil
