Sat Nav Crashed
Garry Westwell
C Class Coupe C220 CDI AMG Sport
Hi All, my Sat Nav has suddenly stopped working, it's just stuck at the road at my home address and doesn't move. I have tried to reset with no joy and also had the battery unplugged for ten minutes with no joy. Could it be the antenna is faulty?
If so, how do I know which one will fit as a replacement .
I have seen the one below on ebay and wondered if it would be suitable ?
https://www.ebay.co.uk/itm/GPS-Ante...843569?hash=item3b0da2ccf1:g:iMsAAOSw0cJa~yET
mattkh
England
A160 W168 1999 1.6
If you know the area you are in, then slowly drive away and see if it works. This will rule out any interference or jamming issues.
Garry Westwell
Garry Westwell
Yep don't this several times and no movement, no matter where I drive nothing happens :-(
sonic
Staffordshire
E350CDI, SLC250d, FJR 1300
There is a good chance the antenna has failed, & for £5.25 this will confirm or not that fault.
Just check its the same connector.
If it is the antenna all you need to do is find somewhere to fit the antenna, & it will save you a couple hundred ££ from Mercedes.
Garry Westwell
Garry Westwell
Brilliant thanks for that.... I am completely useless with anything technical, is there a guide anywhere that shows how to check this please?
sonic
Staffordshire
I am guessing the antenna connector will be on the back of the sat nav so pull it out. Swap the antennas out put the new antenna on the roof in the open & see what happens.
If you cant work how to get the sat nav out Google it, I am sure it will be on You Tube or someone on here will know.
Srdl
New Forest, Hampshire
GLC43 AMG 2018 (X253)
What year is your car Garry? Mercedes have a lot of different Comand and Audio systems so you may need to ensure you get the right fitting.
This link will help you workout what system you have.
Alfie
Surrey/Cotswolds
www.comand.co.uk
If its not moving at all then the first thing I would do is to remove all power, wait and the plug it back in. This will force a reset.
Usually the map will move (incorrectly) even with a failed antenna.
