sat nav disc
petermalone
were do i get an up to date sat nave disc from i have a E270 CDi Avantguard
on a 04 plate:confused:
JemimaPD
also have a sat nav problem that might mean I need to update - and can't find out how to start a new thread - can anyone help:
My sat nav cut out in the middle of nowhere this afternoon, and radio and phone wouldn't then work either. the error code is 0x2312 and it's a comand APS system on a new SLK
Any advice would be much appreciated.
roadhog
Sunny Norfolk
W124 300D x2, C124 300
That sounds like it needs more than an update to me but I'm no expert.
One will be along shortly though. :)
JemimaPD
thank you - any advice would be so welcome as I am clueless with anything technical. I'm hoping it's not going to be a garage job. have only had the car 4 months!
roadhog
Sunny Norfolk
It might help someone to diagnose if you post up what car etc.
Have you got a warranty with it?
Doh! Just read your first post. :rolleyes:
I'm off back to bed. :)
JemimaPD
would have started a separate thread but can't find out where! ( blonde...)
roadhog
Sunny Norfolk
yes I presume it's still under guarantee.
Straight back to the dealer then!
If you click on the relevant forum section (Electrics, Vacuum, Ignition and ECU in this case) there's a 'New Thread' button in the top left corner.
barry jones
Warrington
2016, LWB W222 AMG Line S-Class S350d - W415 Citan Van too :)
Jemima, click on the link at the top of this page that says
"Electrics, Vacuum, Ignition and ECU"
It takes you to the home page of all things electrical. about 2 inches down on the left there will be a button that says "new thread" click that and hey presto!!
Baz
Just go to the main page, "Mercedes -Benz Owners forums" choose where you wish to put your post, in this case it would be Electrics, click the new post button top left, give the thread a tittle and post away
I got beaten to it :(:( With the Coand you must take it back to the dealer, there is nothing that you can do,,it will be the antenna that has failed more than likely
JemimaPD
thanks guys and apologies to peteremalone for hijacking his thread
www.W140.co.uk&www.r129.co
