Sat Nav reset to German
samtam
Anyone know how to change the SAT NAV back into English if I have accidentally reset it to German..
I have a S430 year 99....
Sam
M6AJJ
Norfolk. UK
v222 2014 350
Select and press SYS in any menu (rotary push button)
Select and press SETTINGS
Select and press LANGUAGE (current language in red)
Select and press either English Metric or English imperial.
Good luck!
samtam
How about if it is all in German at the moment...?
Sam
M6AJJ
Norfolk. UK
v222 2014 350
Being that I can't read German, and I am not in the car at the moment, I will try and talk you through the positions on the screen as best I can. Obviously settings, language and English will be in German
1, Press SYS (top left from the rotary push button)
2, Bottom right of the screen, select and press SETTINGS
3, Top of the list, select and press LANGUAGE
4, DEUTSCH will be in red, English Met will be the next one down and English Imp, the next. Once selected and pressed it will take a few seconds then it should show a message ( audio as well if I remember rightly) informing you that it is set to English.
Just press RET (top right of the rotary push button) to come out of each menu.
Hope it works, otherwise learn German, Good Luck
samtam
well I think the English has been blank out.
Does it need the disc or something to turn it back into English?
M6AJJ
Norfolk. UK
v222 2014 350
That is strange, when you first press SYS, it should show the country at the top of the screen ie United Kingdom.
If this is wrong ie Deutsch, highlight and press then change from the list.
Now retry the above.
I still don't understand why English should be blanked out, and I don't know of a disc which is available to the public which would be used to change the language.
If this doesn't work I think it is a trip to the dealers, or as I said "Learn German"
samtam
well i will definitely give it another try..
thanks anyway
samtam
Yeah not in another month though..
The car will be in a ship in 1st of march and then be at the sea for 27 days..
Before i see it again..
