Sat Nav will not accept that the CD is in.
John77
E200 Estate 2011, 2009 SLK 200
2006 SLK 200. I took out the DVD from the Sat Nav out of the player in the boot and when I put it back in the Sat Nav will not work and says that the DVD is not the player, see photos. Any ideas how to fix this?
Everything else works on the in car player.
onefortheroad
uk.
Does the dvd look genuine ?
00slk
Cambridgeshire UK
I've got the same sort of problem, except mine is the DVD not being grabbed to go into the slot.
You haven't got the DVD upside down ? Sorry, had to ask :oops:
MJJ
Wiltshire
'09 S211 E220 Cdi manual - 216k miles and counting
Not sure if this is going to work for you, but I have found a semi-reliable workaround for the same problem on my car's Audio 20 CD player. The root problem is the grabbing/loading mechanism is failing, and there appears to be a very narrow timing window for the player to grab, load and read the CD successfully.
In my case, when the CD has loaded (physically) but getting the 'read error/disc not loaded' error:
1) Eject the CD/DVD, but do not try to remove it from the player - let the eject finish and the disc stop half out of the slot.
2) Now, quickly pull the CD out a couple of centimetres (as if, but not actually removing it) and immediately push it back in again. You are removing it just enough for the sensor to know the disc has been physically removed, but not enough to lose grip of the rubber rollers that load and eject the disc.
3) This should allow the disc to load, read and be recognised as valid.
As an aside, I removed the head unit completely and physically dismantled it to see if I could fix the failing load rollers. Short answer is no, it is so hard to get at the roller mechanism itself, even after removing the PCBs, various sub-assemblies and the CD drive itself.
Martin.
J
John77
Martin.
Thank you for taking the time to reply. I will look at that,
Brian
Botus
S500/2010/500
Fake discs of the wrong flavour will not read.... Fake discs of certain material reflectivity will not read
there's more than one std Merc use the rarer one... I forget which but the opposite from the one that doesn't work either DVD -R or DVD +R
On my fathers car it would NOT eject the disc. So I thought well, there must be no disc in there.... And logic would be, it must know not to load another in a single disc nav device.... That is a bad assumption. It greedily ate another made some shocking noises and stopped. I had to dissemble the flipping thing and extract a nasty mess of two trashed discs... The state of play where the laser mechanism took out the read surface you would think meant it could never function again…. but it does and now happily ejects and swallows discs and works for good measure
J
John77
As I said earlier this is a genuine MB disc that did work until I took it out and put it back in.
Alfie
Surrey/Cotswolds
www.comand.co.uk
Power cycle the navigation drive completely.
J
John77
rifiki
Worksop
CLK W209 W121190B
Get similar problem with my 05 CLK, remove disc clean it with micro cloth. It usually works in my case.
onefortheroad
uk.
Thank you for the reply and this means?
Its a free masons handshake , meaning unplug power from the dvd drive in the boot and reconnect after a few mins.
J
John77
OK thanks I will try these
