Hi all
Recently purchased 2001 S320!!
Sat nav showing 00 sats!! otherwise sat nav working as normal but unable to fix accurate position!
After reading back on all associated posts took antennae off opened up and cleaned off water ingress etc but still no joy! MB want £165 + for new antennae but reluctant at moment as it may not be faulty!
Attempted to remove wood fascia surrounding command and after removal off ashtray screws and ashtray the fascia is loose at bottom but held tight at top around casette insert area!! Is there a tool needed to remove fascia to get at command unit?
There is a loose wire hanging in there which I suspect could be a feed to command for sat nav!!
Any replies would be greatly appreciated!!
An excellent site thanks to all!
