ALFIEBEARD
- Mar 2, 2009
- Age
- 71
- Location
- DUMFRIES
- JAGUAR XF-R SPORT
Well today I was checking the underbonnet area of my E270 CDI W211, if you have already read my other posts regarding the failure of the SBC pump etc and the problems with our local Stealership (Carlisle), you will understand why I am constantly keeping a check on the area this dealer worked on ie the SBC pump,
Well one checking it today I was dismayed to find that hydraulic fluid was leaking from the top of the SBC pump and on closer inspection, what do I find yes you've guessed it one of the hydraulic pipe nuts has been cross threaded in the pump and are leaking fluid, I have attached some photo,s of the pump and the damage the plonker who worked on it has done to the alloy casing, probably with an open ended spanner instead of a correct brake spanner, If you remember when I had collected the car after the 1st attempt of repair I had to take it back because fluid was pouring from these unions, so its pretty obvious the so called mechanic has either over tightened the unions and stopped on the point of stripping the threads, or he has started tightening the nuts when the threads were crossed.
As most of you are aware I have contacted Mercedes UK with a complaint regarding the SBC failure and I am awaiting their reply, what should I do at this point should I again contact the dealer who done this shoddy work or should I get an independant report ?, the main problem about returning it to the dealership is that they dont respect the vehicle or myself and their work is as you can see, done to a very poor standard. as this work is on the braking system I feel uneasy with them touching this car again.
Regards
Alfie B
Regards
Alfie B
