Thats a good price.This will probably be the cheapest SatNav SD card around. I have used these from this supplier and they work just fine.
New! Latest! Mercedes Garmin SD V19 A2139068510 2022 2023 Map Pilot | eBay
Installation is as easy as plug and play. Just insert card to SD slot and everything will be done automatically. C-Class Estate S205 from 09/2014. Countries covered V Class BR447 from 05/2014. GLC X253 from 09/2015 - 08/2017.www.ebay.co.uk
I assume you know where the SD card slot is, inside the centre armrest on the front upright
It depends on what system you have. If you have Comand, then you can play music from the SD Card as well as store navigation destinations. If you have Audio 20, then it is used for the Garmin Navigation system as long as you have that already installed in the car.Hello, I have a C200 2017 with no SD card. My questions is what does an SD car do ? I need satnav and music storage. Any recommendations please ?
Thank you in advance
I've put some music on a usb stick, plugged it into the port inside the armrest and it comes up on the command screen, select and play anything on there, just need to figure out how to pause it now!
i'll give that a go, cheers.Press the Mute button on the steering wheel usually does it
