bahram
- Nov 5, 2010
- Location
- Huddersfield
- C class w203 c200K 2004
- Thread Starter
- Thread starter
- #41
As Malc above, if it fitted correctly and all the bolt are tighten as they should be, then how can a rubber gasket leak, Sarahs car (Missy D) has never had, as far as i can see from the records, a gearbox oil and filter change, that has done 140000 miles in 20 years and is still dry!!!!! hence i have to do it now!!!!!!
Yes I completely see your point. If it was subject to wear and tear it would be service item.
One possibility is that the car may have had atf change and at that time the gasket was not fitted correctly. I don't know if it has an atf change in the past. I will ask the dealer.
