Seat belt extender
White230CE
Hertfordshire
1989 W124 230CE
Hi all,
I'm new to this forum, new to W124's and new to car DIY.
Just bought a 1989 230CE as an introduction to the range. The seatbelt extenders worked for a while, then have just stopped working. They don't extend when I turn the ignition on.
As advised on one thread, I've tried to pull them out manually to re-set them, but they won't move at all - with or without ignition on. How hard do I have to pull?
If it's a fuse, switch or relay, would really appreciate help in locating them.
Many thanks
There are micro switches that can fail in each end of the arm, the control units are behind the trim in C pillar each side
meanie
Oxon
Check the door switch first though.It will only take a couple of seconds.If the interior light is working properly,just swap it with that,they're the same.
Good point I forgot that bit
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Door switch is the most common problem, if you remove the switch they come apart easily and the the pins inside can be cleaned.
jib
W
White230CE
Hertfordshire
1989 W124 230CE
Thanks everyone for your help.
How do I remove the door switches - do they just pull off?
As for the micro-switches behind the trim, how do I get to them and what do they look like?
Ray
They should just pull out, maybe 1 screw
Leave the rest for now it should be just those door switches
W
White230CE
Hertfordshire
1989 W124 230CE
Hi all,
I've tried swapping the interior light door switch with the other. Both switches are working, but no joy with the extender. Contacts were clean, but gave them a rub anyway. Still no joy. Only thing left is that there is some tape binding two wires together - see pic. Is that worth unravelling or would I be barking up the wrong tree?
If it's not the door switches, where should I look next?
W
White230CE
Hertfordshire
1989 W124 230CE
Thanks Malcolm.
This will be jumping in at the deep end for me...
Will proceed cautiously and report back.
Rinehart
Vancouver, Washington USA
1991 R129, 300SL Almandine Red, 102k
not just seatbelt extender....
I have a 88 300ce with a similar problem. The driver side extender works on occasion. I think the problem is with the module that controls the electronic of the extender. (No power coming from the output side) But I can not find a replacement part online. Does anyone have an idea as to where I might find one? Thanks. Rinehart
W
White230CE
Hertfordshire
1989 W124 230CE
Rinehart,
Where is this module located please?
(Haven't attempted anything yet)
it in the sides of C pillar,,I will see what info I have, if any
Rinehart
I have the part number that is stamped on the Control Unit: #1137328053 also another number 0008205826
OK I have 6 pages of how to test and repair these extenders if you would like them please ask
7 emails sent, go back to your post and remove address in "edit"
If you need more info please ask
Rinehart
Seat belt extenders
I have the same problem with the lack of extenders . . . extending. The shop says the problem is probably the Micro Switches. The catch 22 is that they say you cannot replace the Micra Switches without replacing the entire Extender Arm at cost of $600.00 plus labor of $200.00 (USD).
I don't believe that the switches are not replaceable.
Any thoughts or advice???
Micro switches can be cleaned successfully, they can also be replaced , I have changed loads of them by drilling off the heads, and 99% are standard Omron made
Rinehart
micro switches
Thanks Malcolm for the advice. Are the Switches available at Radio Shack? What is the Ohm rating? Thanks in advance for your wisdom. Rinehart
