Seat fitting
Martin blackett
A class W169 1.5 2007 2006 2005
Evening all
Got some leather seats to fit in the W169
Any tips or precautions needed ? Or particular method.
I’m sure years ago I fitted some and the airbag light came on .
Need to u clip the loom under both seats .
Should I disconnect battery first and last or and use a code retaining device with the little battery you plug into the cig lighter.
thanks
ZZZZ
These should help :)
No need to disconnect the battery.
  • 169 Remove_install front seat adjustment mechanism.pdf
  • 169 Remove_install front seat frame trim panels.pdf
  • W245 Remove_install front seat.pdf
  • W245 Remove_install floor covering in rear.pdf
  • W245 Remove_install right rear seat backrest.pdf
  • W245 Remove_install rear seat cushion pivot bearing U57.pdf
  • W245 Remove_install left rear seat backrest.pdf
  • W169 WIS seat cushion.pdf
www.W140.co.uk&www.r129.co
