SEC500 Battery keeps draining
MrsK
SEC500
Hi all :)
I'm at an absolute loss and being about as mechanically minded as a chocolate bar, I have no idea where to start!
My SEC500 keeps draining the battery overnight. It jump starts first time with no issues.
I've checked and I can't see any lights or buttons being on.
I thought I'd check if anything runs while switched off, such as cat seats and windows, nothing. But strangely enough, when the drivers door is open, the car seats and windows move without the keys being anywhere near it!
Any help or advice would be greatly appreciated.
C16RKC
Wisbech
www.youtube.com
2003 CL500, 2007 S320CDi
The cars seats moving might not be a fault, and might be a red herring; it could be they activate so a driver can adjust before getting in, just in case the seat is too far forward.
But it sounds like you have a battery drain, or a bad battery. Your local Halfords will probably test the battery for you.
But after, and assuming the battery is OK, then you'd need to use a multimeter to measure the current at each fuse, and find the source of the drain. I have never done this myself, as I tend to cower out and let the garage do it.
MrsK
MrsK
SEC500
Thank you so much for replying.
I think I'll do the same. I wouldn't have any earthly idea and knowing me I'd muck things up more!
Off to the local garage she will go :)
I’d get the alternator tested by an auto-electrician- the diodes in the regulator pack can fail leading to a random fast discharge - it depends which diode is in circuit when the engine is turned off.
MrsK
MrsK
SEC500
Thank you ever so much. I'm ringing the garage now to get it sorted :)
EmilysDad
Bury Lancs
ML350
.... Your local Halfords will probably test the battery for you.
Not sure I'd let Halfords do it .... I'm sure there must be a proper auto spark local to MrsK
maybe we could 'fix it together' with Diagnose Dan ;)
Seems to be a very similar problem though the fix could be anything.
Botus
S500/2010/500
damp under the carpets keeping something awake is my vote - NICE video
The seats moving with the door open is normal, as this is activated by the comfort relay. Lots of MB's have this around this era.
If you measure the amount of current being drawn, it will give an idea of potentially what is draining it.
MrsK
MrsK
SEC500
Just a quick update. She will be going to the garage this afternoon :)
They will test the battery, alternator and if it is neither of those, they will be going more in depth.
I've also bought a portable jump starter... just in case
I'll keep you all updated. Thank you all for your help and advice.
Slartibardfast1
W221 S350L, R231 SL350 (both sold) & SL400 (current)
We need to see a pic of your car please :)
