Seeking mechanic/electrition for fresh water damage repair
Slick123
Hi all,
I have just purchased a 2006 06 model CLS 320 CDI from an auction. The car is in very good condition however it has some fresh water damage and I''m therefore looking for a mechanic/electrition that specialises in Mercedes to take a look at it as the car does not start.
If anyone can help then please get in touch by e-mail to hussain154@hotmail.com or mobile 07790010587.
Mr Hussain
panason1c
Somerset, UK
Depending on what level of 'fresh water damage' has occured, let's hope the engine didn't ingest any water as you could be looking at piston/con-rod damage, amongst other things, if it did.
Slick123
Where abouts are
you based mate?
Hi Thanks for the response.
i am in didsbury, manchester here is the pics of the car:
if anyone can help please get in touch via forums email mobile number etc...
panason1c
Somerset, UK
I think you might have no choice but to take it into a MB dealership for a full diagnosis on their equipment, the damage to control units (and possibly engine) could range from minor to extensive and whatever is needed is likely to require 'coding' to the car.
star
Reading
Smart + others :)
we repaired an S class with water damage, a guy had it "valeted" with what seemed to be a steam cleaner? All contol units under rear seat, sams ets, srs contol unit, but the worst of it was most of the connectors under the carpet started to corroded. One hell of a job to fix as one minute it was ok, the next things didn't work. :(
Slick123
can see light at the end of the tunnel now!!!
Hey all, just thought id provide you with a quick update, dried the car out with a de-humidifier and used a RAC battery charger to charge the battery (as the battery was completly flat) now all power and electrics are working i.e key fob, comand centre, sunroof, Windows, AC etc.. however when turned fully the car will not strart i do get an error message "dispaly faulty visit work shop" and on the 2nd turn with the key fob the engine warning light stays on
In the manual this could be an issue with the coolant tempreture guage, rev counter or cruise control or speed tronic display.
am just waiting to fully dry it out which i suspect may be another day at least then i probably will take this to MB Tech (warrington).
Thanks again 2 everyone for their comments advise/intrests... Keep it coming.
Mr Hussain
panason1c
Somerset, UK
Thanks for update, keep us informed on any progress.
BlackC55
South coast
C43
I have repaired two of these.
Prepare to spend alot of money and don't expect it back in a hurry.
Slick123
you know what you are right unless you are a mechanic or an expert this is not just for anyone, but to be honist am stuck with it now...lol so in one way shape or form i will sort this out!! but i dont think i will buy a flood damage again...lol
takecare
tricky100
south coast
Problem with flood damage is that 6/12/18 months down the line after everything has been fixed more problems often arise due to continued corrision inside electronic components , which is why seemingly perfect cars are often classified as CAT C rather than just CAT D and if the car has had salt water flooding then it gets alot worse .
And if the water is flood water then the bacteria and can cause some very unpleasant diseases indeed.
Ford used to supply their flood damaged cars to film companies in the US for movie purposes.
nzcosta
Hello,
I bought a C230 from a Japanese auction which was also described as "fresh water damage". I spent till now 2,000 EUROS and it is o.k. Water was ingested by the engine, they tried to crank it in Japan but the pistons were full as well so they tared apart one of the connecting rods. I "opened" the engine and replaced the broken con rod, now drives like new.
Slick123
Hey all thanks 4 the intrest/comments keep it coming.... Its going to MB TECH warrington who are charging me £45+vat to look at it and connect the can etc... hopefully fingers crossed....
watch this space people!!!
MB TECH WARRINGTON
recieved car today so will keep owner posted as soon as we start probing into fault, first impression front sam module, but only looked for 5 mins when transporter dropped it off, so fingers crossed it wont cost him much,
Slick123
  • #17
Dear All,
Just like to tell you all this cost me £1,000 (a thousand pounds) to fix, replaced 2 sam units which had fried now all is ok.
MB TECH thanks for all your help...
Would recommend MB TECH to anyone and everyone!!!
Car is running perfectly!!
"where there's a will ther's a way".
Again Thanks to everyone on this site for their advise and help.
horgantrevor
www.flickr.com
E220 CDI avantgarde c43//amg
enjoy the car they are a great looking car and a great car to drive ......well wear...
www.ckinsurance.co.uk
