Why did they only put back in 2 litres of oil? Even without torque convertor shouldn't it require 4 litres if the sump is removed? Or are W211 gearboxes levels different?
I changed my electro plate, electric plug, oil and filter on my S210 E220 CDI on my mates ramp a couple of months back. Parts wise it cost me pretty much the same but I saved on labour as I did it myself and borrowed his snap on computer to reset the ecu, easy to do but a bit messy as loads of oil. When I drained the oil only about 2 litres came out from sump plug and probably the other 2 litres after I took the sump off?
Stop looking for the Best Garage!! We are here
and have the best advanced solutions for you,
at Competitive prices.
Put us to test with any issue you may have.
