Self Levelling Headlamps
Jeff Richardson
E220 CDI Avantgarde 2005
Hi folks, only recently got into the world of MB. I have a 1995 E Class 22cdi Avantgarde, which failed it's MOT for
  • Headlamp aim too low (4.1.2 (a)
I have read that there can be issues with the control arm from the motor. before I go looking to remedy this, is it possible this could be a fuse issue and be worth checking first.
Thanks in advance
Jeff
Thanks in advance
Jeff
On my later E class ,there is an arm and sensor in the drivers side front wheel well by the spring and one above the rear diff . The arms tend to rust and snap .
Not sure if your set up is the same though
Jeff Richardson
Jeff Richardson
Thanks Wighty, turned out it was the control arm in the drivers side wheel well. Sorted now.
Us E classer’s have got to stick together buddy :cool: . Make sure the rear one is lubed up as well
Agreed, plenty of lube on the rear... :rolleyes:
Jeff Richardson
Jeff Richardson
Thanks for the advice, much appreciated.
www.W140.co.uk&www.r129.co
