Serpentine Belt Tensioner Swap
Rob Collins
Ireland
www.robbycollins.com
W210 E-200 1999 Saloon
Hi Folks,
I was about to replace the brushes on my alternator and noticed a (low rpm) rattling noise coming from the tensioner and thought I'd best replace that along with the belt and brushes.
It's the older style tensioner with the strut that keeps the tension.
Now, I already have an A1122000970 tensioner from a donor car and (before I start undoing bolts) would like to know if I can completely replace the older tensioner and delete that strut.
Does anyone have experience or advice about the possibility of this swap? See below...
Current tensioner/idler with strut:
Replacement(?) tensioner/idler:
M80
Derbyshire
Sorry I can't tell you how easy to replace with the newer design. I guess that would also require some trial and error of replacing the belt for a newer size also.
My thoughts are that if the original tensioner has got through 21 years then going for new and original will se you and the car out. Good enough imo.
MinionBob
SouthWest
Viano - 2012 - OM651 Engine - 2.2
My instinct is you are making a rod for your own back, weather it fits or not (tension could be too low/high even if bolt holes align). Just replace with the same.
Rob Collins
Rob Collins
Ireland
Thanks Bob,
Nice analogy! Went straight to my lizard brain.
I think you're right about that. But I will see if the wheels are the same size. Mainly wanted to update that or maybe swap the bushings.
Let's see...
Rob Collins
Rob Collins
Ireland
Alright!
Just to tie up the thread, I replaced the whole tensioner unit.
New strut, pulley and mount.
Strut was in bad shape, so I could've done it cheaper, but nice to replace the whole unit for not much more cash.
Replaced the belt too, and it's all much tighter. Alternator running fine.
Thanks for the advice.
