Yes it can be reset - there is a procedure that you'll find in your manual involving pressing certain buttons whilst turning the ignition on and off, closing one eye and singing the Marseillaise.
Or alternatively check through previous posts as the question has come up a couple of times recently.
Does the service computer record the status of disc pad wear and indicate when replacement is required? If so, has it to be reset after the pards are replaced?
Or is the pad wear indicator much simpler, i.e. the indicator comes on when pads need changing and extinguishes when the pads have been replaced?
AMF Automotive - We are an independent Mercedes-Benz and AMG specialist located in Paddock Wood, Kent, with full Mercedes Diagnostic equipment. We offer a full
portfolio of tuning options for AMGs and can cater for all your Mercedes needs. Tel: 0203 384 4644www.amfmercedes.com/
