service in dicator reset
Arnie Gunner
Hello,
I did an oil service today on my c 220 cdi w202 and I need to reset the indicator, Im sure this has been asked many times before!, this is my first merc and I am not familiar with the resetting process, I don't mind buying a tool to do it but I don't want to buy the wrong one, am I right in thinking the draper one 24 pin will do it? I assume mercs are similar to bmw's where it's simply a case of joining a couple of the pins in the diagnostic port for a few seconds???.
It's a good feeling this self maintanence lark!
Arnie
pascal
near Dublin
sl320/1999/3.2
no tool required:
Check: http://forums.mercedesclub.org.uk/showthread.php?t=13253&highlight=assyst
or here it is pasted for you:
Pascal said:
Assyst Reset
  • Turn Key to position '2' and immediately press Button '1' (on the instrument display) twice quickly.
  • The service miles will appear on the display
  • Within 10 secs of doing this turn key back to position '0' (off)
  • Press button '1' again and hold whilst turning key back to position '2'
  • Keep the button pressed until you hear a sound signal (about 10secs)
If you do not do exactly as per instructions, it will not work. It is best to print out the above.
Pascal
A
Arnie Gunner
Thanks Pascal,
I will give that a go in the morning, sounds pretty straightforward I appreciate that info very much.
Arnie
A
Arnie Gunner
Done that it worked a treat.
Many Thanks
Arnie
jules335500
king lynn
service indicator on c180
can anyone help with my indicator.did the same oil change plus air filter but how does one turn indicator off. have tried previous thread but when holding button and waiting the ten seconds a 31 14 appears on the screen.
i have 0 and - and + on one side off dash board and the other hour and min .
thanks
A
Arnie Gunner
Hi Jules,
I know what you mean I found the button 1 thing confusing to they actualy mean button 0.
* Turn Key to position '2' and immediately press Button '0' (on the instrument display) twice quickly.
* The service miles will appear on the display
* Within 10 secs of doing this turn key back to position '0' (off)
* Press button '0' again and hold whilst turning key back to position '2'
* Keep the button pressed until you hear a sound signal (about 10secs)
this worked a treat for me.
sorry for the delay
Arnie
