Setting the date and time - W221 / C216
Botus
S500/2010/500
hey.... if you read the instructions. It says the pic below is NOT in the right view for the update to run
must have the focus on the Comand Menu (far left) worth seeing if you had that right ?
MAKE SURE “COMAND” IS SELECTED ON THE TOP MENU, now using the Comand knob, pull it toward you to move the focus to the lower list of options. The first is System Reset and the second is Software‐Update.
index.php
steve.link
CARDIFF
2014 W222 S500, 2019 W213 E220
index.php
Botus - still no luck. I carried out the steps you suggested exactly. Very baffling? I think it must be the discs I have burned are faulty/corrupted. Would you send me the disk you used to try? I will happily pay you for it and postage
Regards
Steve
steve.link
CARDIFF
Just read the MB Xentry Tips document again and it say to check the GPS release number before and after to make sure the update has worked. Mine is 422 as per the attached pictures. Can anybody else check theirs for me?
From the engineering menu go to NAVI - GPS - RELEASE
Botus
S500/2010/500
umm, mine is 423 and you can see the date and time are correct (shows in GMT)
not sure why your's won't work
if you look through the Eng menus you can find the other software numbers, then you can then open the update file as text document (use a copy) and look to see if the part number is supported (most are he built as a global fix) you are looking for the real MB number - but the Eng Nav menus shows this muddled (and on mine). Your displayed MB 2218703591 is not the real MB Number even though its stupidly displays saying it is.
When you print the Merc diagnostic info the MB number for my unit is 2218201426 and you can find it in the list of units supported by the update software, (the equiv of your wrongly displayed MB number for mine is MB2218700591 (and these numbers are not to be found in the update files list)
I made a copy of the Units supported below and where to find in the Eng Menus
CD-Name 2210123456-0001;
[2168209926-XXX];
2164421460-001 \HEADUNIT\CODE_1\ECE\1460\;
[2168200926-XXX];
[2218700391-XXX];
[2218200326-XXX];
[2218200692-XXX];
[2218207826-XXX];
[2218200592-XXX];
[2218201426-XXX];
[2218200392-XXX];
[2218700191-XXX];
[2218700192-XXX];
[2218200192-XXX];
[2218201226-XXX];
[2218700591-XXX];
[2168201026-XXX];
[2168206885-XXX];
[2168209726-XXX];
[2168207085-XXX];
[2168201226-XXX];
[2168207285-XXX];
[2168202885-XXX];
[2218706192-XXX];
[2168701226-XXX];
[2218701992-XXX];
[2168207885-XXX];
MB number as printed in diagnostic here says serial number (which is crap as its not unique). The bottom number is the one you find in the CD update list of Units supported
Botus
S500/2010/500
maybe there's a few files post bird's eye u need ?
when was that update undertaken? its a big update few like to tackle.... but mine was done by Merc in Aug 2014 so maybe other stuff I have is never, I had some fun with a poor connection in the Rear SAM and that kept telling STAR my Comand / Telematics was out of date (Dec 2020 and Jan 2021). I said Yes coz it too new - with the clock fix). But after we fixed the R SAM issue Merc now says mine is all up to date even with the clock fix.
But I still have a bug after some software changes broke the Source mute for Nav message overlay …. been chasing that for 3 years and can't fix it.... its one of their crappy updates that doesn't work. They had a lot of fun and broke all cars updated around 2008 with a Comand update - they couldn't fix it so bodged in a third idea to Mute if Radio is flat out... But I guess they then got some grown up out of the cupboard and it finally got correctly fixed and was always OK on mine before bird's eye and right after bird's eye... I suspect its some stupidity on a rare speedo update ( 4 software files for a speedo FFS !!! that update is a mistake for other reasons (its doesn't even fix the fault they developed it for). I now think that's the cause and probably what got the Comand software guys in a right mess in 2007... and they still don't know about it !!!
check the garbage you can break playing with the speedo ( the order isn't necessarily correct and the options are from a chap in the USA)
Instrument Cluster Variantenkodierung = Coding choices in use
after this " - " is the mode his car was set too
Teleaid vorhanden = Teleaid - fitted
Navigation vorhanden = Naviagtion - fitted
Telefon vorhanden = Phone system - fitted
ART Lampe beim Lampentest aktiveert = ART Lamp on test - on
Lamps Reifendruckkontrolle aktiveert = TPMS - on
Fahrdynamischer Seitenhalt vorhanden = Dynamic seats cornering mode - fitted
Presafe vorhanden = Pre safe brake audible nag - option available on cluster
Ruckfahrkamera vorhanden = Rear View Camera option to enable/disable - option available on cluster
Gurtwanung nach NCAP enstsprechend Konfiguration = Seat Belt function set to - NCAP configuration
Gurtwanung abbrechbar nicht moglich = Seat Belt warning (Visual) - can't be disabled
Akustische Gurtwarnung aktiviert = Seat Belt warning (Audible) - on
Beginn Gurtwarnung ab Motortlauf = Seat belt warning (Speed above) - with engine running
Gurtwarnung Fond deaktiv = Seat Belt warning (Rear Seats) - off
Programmierstaus Kombi ist nicht programmiert = Something isn't programmed - warning buzzer is off
Dummy 1 = Dummy 1 - Ker R105
Reiserechsrnagezaigw Bie 50% Reverve mit Symbol = Less than 50% remaining after low fuel light - Show Red pump symbol
Tankinformation deaktiv = Tank info - off ( extra menu option to see gallons left in the petrol tank)
Tankdeckelwarnung aktiviert = Tank level display - on
EODB Lanpensymbol mit Motorsymbol = EML display engine symbol - yes
Digitaler Reiserechnrtacho anzeigen = Digital Travel Calculator display - digital calculator (taxi thing)
Shift bt Wire Gong beim Ruckwartsgang einlegen aus = Selecting Reverse enables parking sensors - on
Schlusselwarnung aktiv = Key in warning - on
Toleranzband Tachokennlinie = Tacho (speedo display) asymmetric
Limitierfunction deaktiv = Speed limting function - off
GWSZ Vorstellung erlaubt = GWSZ gear selection display ??
Einheit Verraichsanzeige Liter 1/100km = Fuel consumption units (metric) - 1 /100km
Rucksetzintervall 0 km = Reset iterval - 0 km
Einheit Verbrauchsanzeige Gallonen mpG (US Gallonen) = Fuel consumption units (imperial) - US mpg
Fahrwerk ABC-System = Suspension system fitted - ABC system
Dieselvorguhlampe deaktiv = Diesel pre-lamp - off
CHECK-Engine Lampe aktiv = Check engine light - available
Olstandanzeige vorhanden = Engine Oil level warning - fitted
Skalenendwert Tachometer 260 km/h / 160 mph (Serie) = Speedometer range displayed - display 160mph
Getriebefahstufe mit Pfeildarstellung = Gear Position Indicator - displays arrows ??
Getriebeprogrammanzeige nir C/S = Transmission options - C/S only
Version Schnittstelle KI-Externe Module zur HU Version 0 = Version interface - follow K1 from external module HU version 0
V-max Begrenzung Sonderchutz komplett = Speed limit - Special protection
Limiterfunktion deaktiv = Speed limiter function - off
K-Zahl K-Zahl 1 = K-Number - K1
Tachokennlinie Kennlinie 1 = Speedometer curve characteristic - Curve 1
Symbol / Schriftzug US Schriftzug = Symbol fonts - US lettering
Geschwindigkeistswarning deaktiv = Speed warning - off
Fernlicht verlaubt = High Beam - not allowed (???, I wonder if this is when you have night vision and it means inner headlamps off)
Einhait DTR-Skata Feet = DTR displays - in feet
pini0n
W221
sorry, just sent
it should do - mine is correct.
I suggest you check and update the region (country) you have it set on, upon selection (in countries that use it) it rolls on to the next screen with a tick box for use of "daylight saving" or not
you may find when the car next wakes it gets over its jumbled brain.... mine took a while to work out where on the planet it was after the update (not changing on the map for a mile - which was scary - as I knew most USA guys don't use the Nav element as new mapping died for them since 2015... thus was unsure if the update killed the Nav and just allowed you to do the clock. But it does get over its self and works exactly as it used to)...
I think this update does some odd behind the scenes clear out of data that it then needs to rebuild
write to a cd …. writing as slow as possible and just write the iso file, not the pdf instructions.
Its designed to work as if its the real Mercedes update CD.... but everything is ripped out bar the Vespucci time fix. It first starts looking for the tuner... then realises it’s NOT there and goes to next step. Install it outside with the engine running (to keep voltage happy) should be less than 10 minutes....
I found left hand, little finger on the favourite button... thumb and forefinger to hold comand knob to the right, (steadying hand on the trim with other fingers), leaving right hand to do the other buttons.
Hi Botus
Can you email the iso file please? - I have same issue with update firmware CD on my w221and i have read on this forum
email is: pini0n@yahoo.
pini0n
steve.link
CARDIFF
Mine has been back to the Main Dealership in South Wales and they couldn't fix it either!
Botus
S500/2010/500
here's the file (only put the iso on the disc)
The MD5 of the ISO file is d316983fcc0a9e3d8090959524c80f2b
  • NTG_3_GPS_DATE_TIME_FIX.zip
pini0n
W221
Link to iso update File w221,please?
Tnx!
Botus
S500/2010/500
u have 2 links earlier in this thread and the file directly above your post today ?????
Botus
S500/2010/500
Steve,
if the car went to Merc to be checked out and updated but they failed to fix the clock....
you should still have a print out of what they did and what software the care has for the comand
so can you post some clues as to what lies they told you ? and what software the car is running ? I expect they don't have the disc to do the full telematic update - probably didn't even bother to make the clock fix disc either....
pini0n
W221
I see,but is not the iso file with update headunit?!
w221_comand_gps_updatecd_all_hu_v1.iso,please link to file?!
Botus
S500/2010/500
its a compressed file - aka zipped - containing the instructions and the ISO file
its only 1.5 meg as it only the clock fix - just like the main dealers clock fix cd does it (and here as its "compressed" 1.2 meg of air was extracted, when you open it up the air gets put back in) try opening it...
if you want to try and destroy the whole telematics ring using fake offline STAR and some good luck - allegedly the files can be downloaded to make your own CD. But I don't have them
5 days ago which bit of this isn't very clear ?
pini0n
W221
Ok,now i understood! Tnx a lot!
I think is upgrade to complete maps navigation for east europe,sorry!
Botus
S500/2010/500
to update all, is three bits of different software.....
the big update is the telematics update. Its now supposed to be an online handshake with Germany to prepare the car and the tool for the next steps
because when this car was first made the dealer diagnostic way back when would just keel over under the strain - so the actual programming data is held on a conventional CD. So it checks its got 14.6 volt power supply connected, checks Germany thinks it needs it, then tells you the part number of the correct CD to put in the first slot of the comand unit, then it checks the disc really is the right one against their database, when happy, you say GO !!! and you pray the car doesn't self destruct under the stain.
It loops round each module one by one, if its all on original software this update can be 3 hours (most cars' were never updated at all). If its done big miles and if any module is nearly dead, the excitement might be too much for the car and it can die midway - due to the risk its why the procedure moved "online" - so the tool can give a clue which bit self destructed and you can almost affordably fix it (just maxes out three credit cards, rather than needing a mortgage).
Below is a link to USA forum where a brave bloke describes how using a fake old out of date copy of dealer diagnostics (back then they could do offline programming), he did it at home, using downloaded junk off the internet with hacked discs.... (its a very big risk - you'll see he also thought its a simple idea with a map update - its not)
Note: the Air Con is turned off after the update and a session with STAR is required to re-enable the AC compressor
The clock fix was a home made fix by a merc fan boy in USA - it was then adopted as an official fix (using the exact same programming fix in the link I gave)
The map update is a third bit (using a third dics - this time its a DVD) taking 42 minutes and done with the engine running - unless you have a big power supply. Every time it will spit the disc and say failed after 3 mins clunking and whirring - put the disc back in and it does it second time round
After the map update the car can take a few weeks to calm down and find the map info straight away.... its "normal" to see "Activating Navigation" on and off for a few mins after start up for about a week
Botus
S500/2010/500
Steve, may have missed something....
I don't think you replied to my point about the MB number you found is NOT the MB number, (even though it says it is....) please can you give me the bottom number from your system of this ENG menu page
index.php
Bottom of this pic called here HB_APS_DVD-C_ECE is the MB number...
have a guy in the USA can't load clock fix either and his ISN'T on this list of supported units
2168200926
2168201026
2168201226
2168202885
2168206885
2168207085
2168207285
2168207885
2168209726
2168209926
2168701226
2218200192
2218200326
2218200392
2218200592
2218200692
2218201226
2218201426
2218207826
2218700191
2218700192
2218700391
2218700591
2218701992
2218706192
his is 2218700692 (and its not there) is your's
steve.link
CARDIFF
Hi Botus,
I gave up on this tried several times!
Mine is 2218700392 - NOT ON THE LIST ABOVE? How do I update this?
Botus
S500/2010/500
so in a way that's GREAT news...
WOW !!! I wonder if that just a typo the list has 391 not 392 and 992 when the other guys unit is actually 692
So either be brave open the update as a txt file, edit the file adding yours carefully and save, then attempt to rename the file extension and hope the functionality stays in place - A HUGE RISK I DON'T RECCO... or we try and contact the author and get his view but I think you may have a long wait... but as least we have a reason in both cases !!!
I beamed Polar Bear a note asking - but he's not online much on the other forum where he originally shared this fix.
steve.link
CARDIFF
Botus
It didn't work the file that my MB Dealer got from Mercedes either. Would they have the same "typo"?
