Hi all,
I bought a w210 300 Diesel 4 matic, november 1995 about 2 weeks ago.
It reads about 130.000 miles on the clock. (not checked)
As a taxi driver in Holland I've driven so many w210's of all versions, over the years that I feel there are some things not like they should be on my MB.
1 ) First of all I can hear a bearing-kind of sound from the rear end, I suspect the right wheel, but am not sure what to check, I jacked it up but can't feel any free play, when I turn the wheel I can something scratching and it looks like if it's the brake pads / disc, but visually they look fine! Also the pitch of the sound stays the same at all speeds, but doesn't go away at any speed.
2) When I hit a bump in the road, any speed, but located under one of the front wheels, my steering wheel gets knocked around left / right and back to center, but driving the car on a flat surface feels ok.
3) When I park my car the power steering seems to work intermittently light / heavy / light / heavy steering. :-?
4) I can hear some sort of low-pitched humming / vibrating noise from the front of the engine when idling (it does run smoothly on all 6) when I rev it up just a tad, the noise dissapears.
5) My gearbox shifts beautifully, except when driven in a cold state, then it seems like it's just throwing it in the gear without even using a clutch. (I mean that is what it feels like). but when I've driven the car around a bit it just shifts beautifully. 8)
6) last but not least, my alarm / doorlocking remote key thingy, I have the old version, in which the key can fold into the hole thing, it's is operated with I/R lights. I went to the closest MB stealership and they would charge me 267 euros, something like 200 pounds? for an extra copy, as I got my car with just 1 key , is it possible to get original keys cheaper? Those keys are more valuable in weight then gold is!
You are all wondering why did you buy this car? It looks great, the engine runs great, and it hasn't leaked one drop of oil anywhere. And........ it was dirt cheap.
Hope you can help me out on some things!
gr.
hollik
p.s. great forum you guys got here!
gr.
hollik
