Shaking car at low temperature
Sully3087
W204 C250 CDI 2011 - Facelift
I have been having a problem with my C220 CDI 2003 in the last few weeks.
When the outside temp is lower than 5 degrees i get the following symptoms.
Car starts to shake every 10-15 seconds in idle mode (like its misfiring). Rumbling noise from under the bonnet near the air intake manifold.This dissapears as soon as the throttle is applied. Once the car is stationery again and in idle mode the symptoms reappear.
Symptoms completeley dissapear once engine temp reaches 80 degrees.
When the outside temp is higher than 5 degrees like today - no symptoms at all.
I have been to the dealers who initially replaced the fuel filter - no change.
The dealers then replaced the alternator pulley and tensioner - no change.
Can anyone please help and give me some advice.
Sully.
Sully3087
Sorry.
Its Auto
Quick Silver
Moonshine Island, surrounded by water
R129 1990 SL 300..
Sully.
It's shivering co's its cold ! Dont you ? Seriously now I hope you find the cause and let us all know ,it's certainly a strange one .
G-a-r-y
Bristol
S211 320 CDi, SLK 200 R171.
Don't these cars suffer from engine mount failure (hydraulic type.)?
I was thinking that the car was a bit new to be the mounts, though things can fail
Sully3087
Thanks for the replies guys.
How much would I be looking at to get the mounts replaced / repaired.
And furthermore, is it damaging the car in any way.
Cheers
You can see visually if a mount has gone as the engine will be inclined in one direction.
The fact that it does it only every 10-15 sec gives me doubts on this, and why not a sticky injector when cold, or something of this nature
Sully3087
The engine seems quite level.
And you are probbaly right as if this was the case then it would shudder all the time not every 15 -20 secs.
I had the no 3 injector replaced a couple of months ago as the car was shaking all the time in idle - hot or cold.
I wonder whether it was not fitted properly.
Thanks Malc.
Thanks Malc.
Malc,,try some injection cleaner, its cheap and and just put it in the tank, the Millers4 would be the best
Sully3087
It is going back into the dealers tommorow. Will mention it to them.
Thanks for your help Malc.
Will let you know the progress on Friday.
Sully3087
Feedback on this problem.
Took it into the dealers and i told them to check the injectors via a diagnostic.
They kept it for 2 days and told me the injectors were fine but diagnosed the problem - "the coolant heater was not activating at the right time, putting a load on the engine ???"
They have adjusted the settings, and it is fine now.
Thanks for your help guys.
A strange one but thanks for posting back
