simon
M-B bonded windscreens provide around 35% of the vehicles torsional strength & are designed to support the weight of the car when its on its roof.
Factory approved installation should take circa 6 hours(Curing/environmental).
Recent enquiries to local/national windscreen fitting centres suggest that most use M-B supplied screens or direct from OEM. Auto Windscreens use their own sourced glass but will fit M-B on request.
Replacement necessitates removal of trim/headlining around the screen aperture.Sealing/bonding agent has to be injected in dry conditions & after glass insertion should be left to cure for several hours.
Fitting centre always offer to come to you to replace glass. Franchised dealers, due to sheer numbers, obviously have less experience & are reputed in some cases, to call in the local fitting centre to do the job.
Have you had a replacement windscreen fitted?
Was it successful? Where was it done & by whom?
Ernest Sidesman.
Ernest Sidesman.
