Shorted the Rear Relay/fuse box? S320 CDI
mouldb
I was re-fiting the rear fuse box under the rear seat after fitting the tow bar electrics when I brushed the thick red live cable on the bodywork. The car starts, drives & front electric windows etc, etc. However when I start the car up, it says on the console (the display is defective visit workshop). No fuses appear to have been blown but the following things will not work:
Central locking
Boot release
Rear electric windows
Steering wheel automatic movement.
SRS light stays on dash
Does this sound like it Just needs taking into the workshop for a plug in & fault code re-set, or should I start crying now?
Regards,
Bruce.
Central locking
Boot release
Regards,
Bruce.
Hi Bruce OK if I go to bed and think about this, I am out for a while tomorrow but I wll look into it and see.
M
mouldb
Thanks Malcolm!
Bruce.
M
mouldb
Help!!!!!!!!!!!!
I am taking the kids away for the weekend, tomorrow & am in real need of help!!!
I cant close the rear window.
Bruce
Can I have the rough build year for the car, i know it is a 220026.
M
mouldb
2001 S320 CDI
Ta,
Bruce
Relay K40-5 supplies all the power to the rear fuse box
its in the right front fuse box
M
mouldb
Malcolm,
I have a fuse "K" but not K4-5, is this the same thing? The only ref to go by is the fuse & relay list/sheet in the car.
If I am unsucsessful & it is getting dark, would a 55amp battery be ok to put a direct feed onto the window motor to wind it up?
Thanks ever so much,
Bruce.
Malcolm,
Bruce.
This K40-5 could have blown then put the battery over the wire that you shorted to ground
You have K40-5-6-7 in one of your front boxes
M
mouldb
Malcolm,
Excuse my ignorance, but do you mean a live feed from my spare battery to the red power cable i shorted?
Bruce.
Malcolm,
Bruce.
Yes that was live once,it as far as I can see the k40-5 supplies all of the voltage to the rear fuse box, as this must have blown there should be no harm in back feeding it, so yes join that up to the battery.
When I say left and right, the could be reversed as my info is USA
M
mouldb
Malcolm,
Would it be possible to send me a diagram for reference?
mouldb@nildram.co.uk
Thanks for all your help,
Bruce.
Malcolm,
Bruce.
ref to which bit please
M
mouldb
the relay/fuse box (K 40-5) etc, etc.
Ta,
Bruce
What a night, after that guy eric starts on me,I could leave the forum for ever. I should not really answer anything, my head just spins.
My computer locked up 3 times sending the Emails, so I have sent 9 separate pages that I printed off first
I have been looking in the wrong files, yours is the 613 engine, that puts every thing in the rear box. You do have power there as the fuel pump relay runs.
You have pile of fuses here number 50 onwards, that leaves the fault within or around K40-5
Page layout sent
M
mouldb
  • #19
Hi Malcolm,
I know the feeling!! after the day i've had, I have to take the wife & kids to loch lomond for 3 days, setting off at 08.30am in the morning......
The car drives fine, hope it gives you a clue!
As for the forum, your help has been invaluable, & greatly appreciated by many!
Bruce.
Hi Malcolm,
Bruce.
If I am still here I will take it further with a clear head. Do have a good trip best regards
