rf065
- May 30, 2007
- Location
- Grossbritannien
- SLC300 - C250d Estate 4 Matic & Z900rs
With other cars when I use the windscreen wash (when you want little more than a mist of water on the screen), I usually just press for a second and the jets of fluid hit the screen almost at once. I've noticed with the CLK, a quick press does nothing and I have to press again before anything hits the screen. Is this normal for a Mercedes, or do you need to hold the button for 2or 3 seconds, or is there a one way valve somewhere allowing all the fluid to drain back to the bottle, as I suspect might be the case?
Russ
Russ
