Oh nice 30mm seems quite a significant drop I didn’t think it would be that much, looks like any more than that and the wheels would rub ? Also did you keep the stock shocks ?
Yep, stock shocks, withOh nice 30mm seems quite a significant drop I didn’t think it would be that much, looks like any more than that and the wheels would rub ? Also did you keep the stock shocks ?
I posted that as a new thread don’t know why it posted here as a comment .. I’ve seen that pic, this thread was started by me..see post 4
Multiple threads on the same subject by the same person are either merged or removed as it causes confusion for members.I posted that as a new thread don’t know why it posted here as a comment .. I’ve seen that pic, this thread was started by me..
Yeah thought so , only got 1 pic last time so thought I’d try againMultiple threads on the same subject by the same person are either merged or removed as it causes confusion for members.
If more replies are sought then posting again on the thread is the best way of bringing it back to the top.
Most members are against modding, Full Stop! but as said many times, everyone is different. (Thank god)The lack of response suggests that most 212 owners on here are happy with standard set-up.
Fixed that for you…Most members are against making their car worse, Full Stop! but as said many times, everyone is different. (Thank god)
Using your Power, Russ.Fixed that for you…
What do you think about the comment above this one by malcolm210? Did you have trouble when lowering yours ?Most members are against modding, Full Stop! but as said many times, everyone is different. (Thank god)
Nope, H&R ask for your chassis number to make sure you get the correct Springs, simple's.What do you think about the comment above this one by malcolm210? Did you have trouble when lowering yours ?
Yeah I mean we just have to make sure the springs we buy are going to fit right, that’s all.. ?Nope, H&R ask for your chassis number to make sure you get the correct Springs, simple's.
In a Nutshell yes, when used with the original wheels, if you start changing the wheels, for bigger, wider, different offset for example it then becomes a bit harder.Yeah I mean we just have to make sure the springs we buy are going to fit right, that’s all.. ?
