Side indicator issue
gpt
W169 A180 2009
I have a fault on my 2009 W169 A180, it works intermittently and cannot decide if its a faulty led unit or broken wire, symptoms are:
With indicator or hazards on it flashes 2 or 3 times occassionally. A single led at the outside end flashes most of the.time. Folding the mirrors has no effect on it working / not working. It flashes as normal when locking / unlocking. Sometimes the speed increases (indicating bulb not working). Sometimes i get a dash.message that the right.side indicator not working.
The only 'constant' seems to be the correct function when locking /unlocking.
Thoughts appreciated.
Gary
G
gpt
W169 A180 2009
Thanks. Is this part of the.indicator unit?
Larkone
NW Essex
C219 CLS 320CDI 2008
Yes - unless you can find an electronics whizz to diagnose and fix its a new lamp unit
SL63 Mark
Wilts
R231 SL63 AMG
The above sounds very plausible, however, it might be worth getting it diagnosed before playing "parts darts".
Larkone
NW Essex
You would have to do this with the electronics whizz to fault find on the driver board. I had exactly the same issue with my LED indicators in that they would work for a couple of flashes then stop. It was the LED driver board inside the light unit so cannot be directly accessed by STAR other than there is a fault in the light unit and it cannot be bought as a replacement part, only the complete lamp unit.
My wife's BMW had a rear LED light fail for the same reason and I replaced the light unit. I still haven't found anybody that was prepared to diagnose what the issue was on the driver board because of the tiny SMD components - big winner for the manufacturers
G
gpt
W169 A180 2009
Thanks for the replies, really helpful. Just trying to rule out a broken wire which seemed unlikely but apparently fairly common with folding mirrors.
I'll get a light unit and give it a go.
Gary
G
gpt
W169 A180 2009
Thanks for advice. Faulty unit, replaced and workimg ok now.
Cheers
Gary
