side light bulbs
Morzine
Germany
E class W210 1998. When I look at the front side lights I notice 1 side brighter than the other, do I have two bulbs for each side and 1 is out?
Anyone know?
Cheers,
Anyone know?
Cheers,
Only by inter changing them, or by fitting a matched pair will give an answer.
Malcolm
Only 1 each side for side on my 210. Check the bulbs, the bulb sockets and the wiring.
M
Morzine
Germany
I'll change them over and see what happens, thanks for now.
carabind
Lancashire
e class
They can possibly dim with age, or could be a loose/bad connection. I'd try two new ones with a squirt of WD40 or similar (switch cleaner) into the bulbholder for good measure, as blobcat says
WD40 is not a switch cleaner, and should not be used, plus if it was a contact problem,the lamp would fluctuate with temperture changes, sorry to be difficult on this,but is is a fact.
Malcolm
Ultymate
N. Wales
C230K Estate 1998
Could be the glass envelope part of the bulb they sometimes discolour going either dark grey or a murky yellow. for what they cost I'd buy and fit two new bulbs if theres still a disparity you know you've a problem on the dim side likely as not a bad earth :???:
One more bit of useless info is that with side / tail lamp bulbs, there is no beam pattern to them and two different manufactures can make lamps say 21 w but can appear to have a different light intensity at different angles.
Malcolm
