Silent alarm ....
The other week when we were away, my alarm went off in the early hours. It stopped & set off a couple of time while I was trying to find keys to silence it. It did it once when we got home but I found a stow away bug in the car and assumed/hoped that the two were connected.
Just now a friend called and commented that my hazards were flashing but no alarm. So I set the alarm with the window open (just discovered the door won't open from the inside even when the button on the door raised :)) waved inside the car, got a very short blast from the siren and that was it .... silent alarm with hazards.
Went through exactly this with the R Class
Andyn666
2003 W211 E320 CDI estate
Same as my Eclass, it will almost certainly be the alarm siren batteries leaking acid into the PCB, that shorts the connections and causes exactly what your describing. Once you remove the siren all returns to normal, obviously your alarm won't sound untill you replace it.
gassed up
liverpool
2011 C207 350CDI;2010 C207 350CDI sport;2010 SLK300;2004 C209 320;2000 C208 230K;
Alarm/siren unit is fubar. Easy DIY , usually sits behind near side front wheel arch liner. Genuine Mercedes on eBay
131303721655
131303721655
Thanks for the link but that would mean me putting my hand in my pocket ...... the car came with 12 months warranty :):)
