angst
Being a bit of a DIY person I've logged a couple of hours fitting an MB Bosch wiper blade to the central arm of a 1989 260E W124 model.
I think I could be almost there with a bit of help.
The first hour was spent working out that the curved end of the wiper arm fitted into the middle of the wiper blade clip rather than over the end of the clip - as it did for every other blade I've handled. The diagrams on the box bore no relation to the product inside it.
Problems still remaining are:
1. The blade is asymmetric - the central pivot off centre that is - and according to the box the long bit points up for models from 12/87 and point down for models up to 1/88 but I'm assured it's the one for my car even though it seems to be only for cars made in Dec 87.
2. Whichever way I put the blade it leaves a blind spot left of centre of windscreen. I've already exchanged one of these from German French and Swedish, which also had a tear in it as well as the blind spot.
The main dealer is miles away and couldn't help over the phone, saying they don't measure the distance from the top of the blade to the top of the windscreen and don't know which way it should go in.
Any advice including:
A. Does your long bit point up or down if you've a single wiper?
B. What is the distance between the top of your wiper when vertical and the top of your windscreen if you've a W124?
would be gratefully received. I'm hoping to have the blade sorted in an under four hour task so I can move to even more challenging areas like working out how to replace the back interior bulb without hacking at the cover.
The sad thing is, I had no problem with the old Bosch blade that was just an 'any car' blade rather than one specially built for MB.
