After just getting my SL 500 back on the road, the folding soft top has just stopped working....
Folded down ok, then refused to go back up. Ended up doing it with the spanner in the tool kit.
Hydraulic pump in the boot floor is ok, and ive checked the fuses but none have popped, and once roof is shut and locked it, when you press the close switch, it tries to pull the roof down as if it should work...
Could it be a relay or switch, or maybe sychronisation problem...its worked ok for the last 3 weeks with pretty much daily use....
Any advice guys?
Any advice guys?
