SL 55 AMG Clock
Status
Not open for further replies.
Phynyxun
Good Evening All.
My Father and I are starting to get annoyed with the clock on the dashboard of my Fathers SL 55 AMG. Every time I get in the car I change the clock back 1 hour (GMT) however every time the car switches off the COMAND GPS timer starts and sets the clock forward 1 hour.
Is there any way to override this error?
Thankyou very much for any replies or help with the matter.
piestore
manchester
command
this is not an error in the command system, it is not set up correctly
press the system button and select time, make sure that country time is correct, you can select automatic summer time or not, and if you wan't to have some strange time on the clock you can program the cluster not to use GPS for the clock. Call into your supplier i'm sure thay will do it for you
Status
