SL battery warning light
sl5
SL500 R230 11/2002
hi
i have been trying to fix this battery warning light ever since., '...visit workshop'.
i have replaced the alternator regulator.. it was fixed then after 2 hours, it started again..
now, everytime i turn on the engine, it says 'consumer electronics offline'
and have to restart the car in order for my steering, seat to set to my set configurations...
maybe rear consumer electronics battery is dead.
and would this be why i am getting this warning light? can i recharge this or do i have to buy another battery..
drmw
Yorkshire
www.autonomed.co.uk
If the alternator has been replaced, then this is indeed the battery failing to hold enough charge.
Cold weather and batteries on their way out do not go well together!
sl5
SL500 R230 11/2002
hi
no, the regulator was changed only
which battery needs changing, front or back?
sl5
SL500 R230 11/2002
I mean regulator was only changed not alternator
Hello, you do need a voltmeter to check and see what is going on. I take it its a 230 SL
You need to check across the rear battery to see that you have around 13.8 volts with the engine running. If the voltage is staying at around 12volts, then the alternator is not charging or the battery control ECU is not working, this is the one behind the rear battery in the boot, the front battery is for the starter only
sl5
SL500 R230 11/2002
hi
ok, thanks. i just took the readings..
front battery,
normal: 13.3 v
engine on: 14.6v
rear battery
normal: 12.1v
engine running: 14.0v
does this normal?
Yes that is perfect.
You must remember that it will take up to 20 hours to get the rear AGM battery back to its full charge, this is on a 4 amp charger
sl5
SL500 R230 11/2002
so youre saying i should just charge the rear battery first with a external charger instead of buying one?
if i do remove the battery, would it wipe out any system configs, memory,etc after a certain time?
Most of these AGM batteries are good for 10 years
If you disconnect it, you will have to reset the windows and possibly the roll bar, the ESP lamp will go out on its own when driven.
My SL was never used that much and every 2 weeks I gave the rear battery a good charge or the "consumers off line" message would be up for some time.
The SL draws high current for some time each time you turn off, this is while the car is going to sleep.
Charging the rear battery works wonders, and the charger best left on till the charge drops to 2 amps or just under.
My 2002 AGM battery from my SL is in daily use still in my CL do charge it first, it can take a 500 mile trip to get the battery to the same good level
sl5
SL500 R230 11/2002
thanks... i am now charging the battery in doors.. so its around 20hours? untill fully charged?
When you refit it,,, just turn the key to ignition on, close each side window on the the slow lift and hold the switch in that mode for 5 seconds.
There should not be anything else, the ESP will go out as you drive
sl5
SL500 R230 11/2002
i started charging my battery, after 1 hr, it says 'fully charged'..
whats going on? is it dead?
Where does it say fully charged, what was the current going in
sl5
SL500 R230 11/2002
4amp
it said it on my external battery charge.. greeen led, fully charged.
Its hard to know what to say as AGM batteries have different charging characteristics over a lead acid, I do know that it is easy to get the AGM batteries up to 12v, its getting that last ½volt that can take the time.
Try it you never know
SL63 Mark
The South
R231 SL63 AMG
4amp
I don't think you have the right sort of charger. It needs to be AGM specific, a trickle charger/conditioner. Mine takes 20 plus hours as Malcolm says. It has a complex charging cycle, which is designed not only to charge the battery, but to gradually restore it to full health.
