Sl R107 Dashboard
ifzal
I want to completely remove the dashboard of my SL as I have a small leak coming from behind the dash. Ive been told that its a leak caused by rust around the heater intake boxes.
Having looked at the leak It would appear that I will have to remove the dash inorder to repair this. Has anyone done this before as I know its a common fault on the old SLs?
Secondly, how big of a job is it removing the dash and then replacing it? is there anything that I should be wary of?
pascal
near Dublin
sl320/1999/3.2
There is a thread on here somewhere with details on the removal of the whole dash of a w124.
tom7035
Ifzal, first check your drainage holes/tubes right in the corners of the lower windscreen channel. I was getting a wet carpet on f/p side until I discovered a totally blocked drain tube on the n/s, and since clearing it out, no problem. (May just be coincidence, but I don't think so). However, I would advise against just poking a piece of stiff wire through for fear of rupturing the tube part-way down. I just happened to have an old outer casing of a bowden cable (bicycle brakes) lying around and this was perfect, no sharp end and very flexible. Worth a try, only take a minute.
I
ifzal
cheers for the feedback chaps. Will tell you how I get on.
Pascal - that link doesnt work.
Im new to the MB experience but having bought a 1976 350 SL I think its gonna be a challenging but rewarding experience. :-D
pascal
near Dublin
sl320/1999/3.2
The first one to wanado should work ok. If you have poups disabled, hold ctrl down whilst clicking. All links from this site are popup windows
The second was just a search, sorry. Just put 'dashboard removal' or just 'dashboard' in the search box.
Nourade
New Registration
Gulf Coast
1987 560SL / E500 1991
R107 Dashbord removal
Hello there, I am trying to remove the dashbord from my 560SL. However, the links in this page are not working anymore. Please help:(
