Nile Griffith
- Oct 10, 2017
- Location
- Worcestershire
- 2009 Sl350 R230
Hi Kids!!
"An SL R230 with a PSE problem? Surely not" I hear you cry in unison. Well here goes, a call out to the hive mind so to speak.
Problem/Symptom.
On opening car from outside with remote key fob, drivers door (RHD) does not unlock, plunger does not raise. Closing the car from outside with key fob, all doors lock (well there's something).
Inside the car WITHOUT ENGINE RUNNING. Using central locking button on dashboard, as above. Passenger door unlocks but not drivers door. All doors lock.
Inside the car WITH ENGINE Running. Again using dash mounted central locking button, all doors lock and unlock without problem.
Initial diagnostics.
No audible signs of air leaking.
Battery in boot shows 12V when measured. Engine running 14v at battery terminals.
Observations.
The working sound/tone of the PSE pump is noticeably different when the engine is running as opposed to when working from battery power, assumption is that the extra 2v is turning the electric motor just that bit faster.
So brotherhood of the Teutonic'ally frustrated. Any thoughts? I'm against lifting off the door panel (cos' they never go back the way they came for starters) as if it was a lock issue the the problem would be consistent whether engine was running or not and I can't hear any air leak when listening to the door.
If it was impeller issues with the PSE pump, would the extra spin that 14v provides the Pump's motor with, be enough to overcome any issues, but all the other locks seem to operate fine (although the boot has always been a bit slow to activate/release).
I'm inclined to err towards an issue with the solenoid inside the PSE pump that opens/closes air flow to the drivers door lock, but..........
What I am trying to avoid is just blindly wading in pulling stuff apart, stuff that on twelve year old vehicles that doesn't always want to stay together as originally intended. So if anyone out there has had a similar issue I'd love to hear of it and what your fix was. Or maybe I just bite the bullet and sell a kidney to fund a new PSE pump.
Thanks in advance to all.
Problem/Symptom.
Observations.
