SL320 Disk Brake Rotors (handed or not)
MagniMike
Fance
SL320
Hi
Can anyone advise if the front disk brake rotors are fitted as "handed" left and right ?.
I have a pair on order from an after market supplier as opposed to OEM, but the vented fins point in the same direction, so when fitted one set of fins would point to the rear of the car.
Suppliers say that they are not fitted as "handed" parts, is this correct.
SL320 (aug 1999) V6 Auto
Tks Magnimike
That is correct and they will point in different directions, even the Brabus 230 does this
MagniMike
Fance
SL320
Hi Malcolm, many thanks for the advice, will now purchase with confidence.
Rgds Mike
Rgds Mike
I bought a pair of OE Zimmerman disc from my normal parts supplier for £100 the pair
MagniMike
Fance
SL320
Hi Malcolm - these are also from Zimmerman from GSF same price, cant be bad.
Rgds Mike
Rgds Mike
Thank you, I did not know that GSF did them :D:D very useful for other people
MagniMike
Fance
SL320
Just in case anyone is interested,
Brake parts from GSF for an SL320 V6 auto 1999 are :-
601ME0601 Front disk rotor (334mm) vented MB part No = 129412112
M64024 Front pads
M62351 Rear disk rotor vented
M64131 Rear pads
M64204 front & rear sensors
Rgds Mike
Roughly £250 I would guess at
MagniMike
Fance
SL320
Costs as follows :-
601ME0601 Front disk rotor (334mm) vented MB part No = 129412112 £55.00 each
M64024 Front pads £54.00 set
M62351 Rear disk rotor vented £46.95 each
M64131 Rear pads £19.95 set
M64204 front & rear sensors £1.50 each
GSF at Daventry
Rgds Mike
5pares
Suffolk
E320cdi
Seems strange they dont have sided discs as one side will be fighting against the wind.suppose it comes down to cost.The only mercs ive seen with sided discs are 129 sl 600 v12 and 210 E55.
Not to feel left out, my handed too ! 91 SL500
This is interesting as they do not seem to be any longer, and it has caused a few fix ups as to whether they have or not
