SL350 lots of electrical problems at same time
Devonian
My son's R230 (2003) has just started exibiting many electrical problems at the same time, symptoms include:
central locking not working,
dash displays shows error with roof - visit workshop,
battery error - visit workshop
only some of the instument cluster displays are working
All these occurred at the same time, I'm hoping that maybe it's a low battery causing all the errors though after a 20 mile run they were still there.
Has anyone had these symptoms before?
Fleetwood
Horsham, West Sussex
2005. SL350
Yep sounds like water under the passenger carpet
I had this with mine, I was lucky that I dried it out and all ok
vauxhallmaniac
SL350/SLK320 Special Edt/SLK320 "Tinkerbelle Edition"
Yep sounds like blocked drain N/S/F wheelarch, look in the blower motor air intake n/s of bonnet should be empty if its got water in it you have a blocked drain the water has flodded in through your blower motor and under the n/s carpet and is shorting the CAN electrics :(
www.W140.co.uk&www.r129.co
