Alex Crow
- Jul 9, 2009
- Location
- Super Suffolk
- W169, W124, w202, W203, KTM 250 EXC, VW T25 camper and a Polo in a pear tree
that code 18, it is in the DI (ignition) module isn't it?
if so test 23=>5.0 directs to connect an oscilloscope to the crank sensor pins at the ecu (N1/3, ignition module on inner wing, pins 17+18, the screended crank sensor plug). then crank the engine and compare the trace with 25=>fig2 which shows a regular oscilloscope pattern with alternate up/down spikes above and below 0V seperated by flat line, with one up/down deflection all in one, once per revolution - this is from the magnet.
simply put, if you find someone that can connect and use an oscilloscope, get a trace of the crank sensor when cranking and they should see the trace from the magnet, once per revolution. this will be amongst many other traces/spikes/signals from the regular reluctor teeth bu the oscilloscope operator will know what is what if you relay all the above info.
