merc300e
hello - I am selling my SL500 1997, last sunday a buyer showed interest and asked me to take the car for an inspection. I took the car to a garage, it came out with nearly £3k damage. The problem is with the roof system. Prior to this I had no problems, including demonstrating it to the buyer 3 days before, and refitting it the night before with a neighbours help. The roof system is electronically monitored and flashes the red roof switch/sounds a chime if there is a fault. When I got in the car, after the inspection, at the garage it was doing both. I watched the technicians working on the car. One had a fault code reader plugged into the engine, engine running and was having dificulty getting it to work, in fact he stalled the engine at one point. The other tried to remove the hardtop by pressing the switch - again with engine running. It did not lift. He immediately got the manual emercency release tool from the boot kit and removed the hardtop manually, still with the engine running. After he replaced the hardtop the warning light was lit. Other possibly useful info: he had the front wheels jacked off the ground - I am told they have a switch that detects this and activates the roolbar. A number of Merc technicans I have spoken to say they would never attempt to manually remove the roof whilst the engine is running as this is known to cause problems with the system. Can anyone out there offer me any advice please - does anyone have access to the merc workshop advice on removing the hardtop with this tool or can confirnm that it is known practice to use this tool only with the engine stopped.. Could a fault code reader cause damage to this electronic module if it was faulty/wrong type/misused? The new roof module is £2300 from Merc and they want £93 per hour to sort it? Does anyone have a roof module- Part no:129-820-3126? The garage says it just happened to fail at that point in time. I say it worked for 7 years and its a bit of a coincidence it failed in the 20 mins they were working on it. Also were do I stand in that when the technicial found the roof was not lifting why did he not just simply report the fault and leave it at that? He was not being paid to work on the car. I would be grateful for any help. Thanks
