Sl500 roof not closing or opening
Sl500 2003
Sl500 2003 5.0 v8
Hi all,I finally purchased a sl500 2003 model.petrol 5litre v8.
Today I opened roof with key remote.boot lid opened, arms came down in boot and that’s it.
When I go to open or close roof with button inside car.it says close boot lid. Then it says in operation. I have disconnected battery and boot nearly closed. But has. 2 inch gap. Dash board shows same message.
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
Am guessing that you tried opening the roof on the battery.
Perhaps retry the opening, closing with the engine running as could be a flat ish battery.
Now that you have disconnected the battery I think you will need to reset the windows so that the roof module knows where they are and can operate.
Reset the windows before retrying the roof.
ajlsl600
france
As above ,most likely cause.or micro switch out of position
Sl500 2003
Sl500 2003 5.0 v8
Thanks for reply, I tried with car started with no luck. Not sure how to reset windows?.also where should the micro sensor be?.
Thank you.
Wearsafoxhat
To reset the windows you need to lower the window and keep the switch held down for five seconds, then up and hold for five, then the other.
As for switches, there are many. The load cover one is often guilty, but could be any one of them, or two
Far better to find a good MB independent and have them read the fault codes for a quicker diagnosis. These are very nice cars but a little complicated.
Sl500 2003
Sl500 2003 5.0 v8
I will try window reset today and let you know if works.
Thank you
Trying to find a mb person too
Wearsafoxhat
If you give a rough location of where you are, someone on here is likely to suggest a good place to go.
Sl500 2003
Sl500 2003 5.0 v8
I’m in slough Wexham area mate
flowrider
SL500 (R230)
The attached may be of some help........
  • Vario Roof Diagnostic Aid.pdf
Sl500 2003
Sl500 2003 5.0 v8
Thank you very much
Sl500 2003
Sl500 2003 5.0 v8
Hi, turns out it was due to low battery.
I removed battery, put on charge over night. Reconnected to car. Asked family member to sit inside car and press roof close button while I pushed down on boot lid. It locked and partially closed. After that I pressed roof button to open and then close. All worked as it should.
Thank you for your help.
Wearsafoxhat
Glad that you have it sorted out. A low battery can cause a lot of small problems on most Mercedes.
Thank you for posting the end result.
