SL500 Roof
oscar wightman
I wonder if anyone can help me out...
I have a 97R sl500 and it has been standing for a while. The hardtop will not unlock/comeoff etc... Also, will the roll-bar still operate if the hardtop is in position because, if so, that is not working either!!!
Just for info... Opened doors, unplugged rear heated screen, put key in ignition to position 2 and then pulled the roof switch back withing 10 secs... and nothing... (just incase i am doing anything wrong).
Wonder if anyone has any ideas or will it have to be taken to merc....
Many thanks...
Oscar
Myros
R107, S211, R170, C219
Having read some of the other threads
get your engine started, go for a good drive to juice up the battery and try again.
pascal
near Dublin
sl320/1999/3.2
Does the light on the switch flash when you pull it back?
Also, If your battery went completely flat, you will need to do a window re-set.
Pascal
O
oscar wightman
No, the light does not flash...
How would i go about getting the windows reset? Will this effect the roof operation?
Many thanks for your replies and help
pascal
near Dublin
sl320/1999/3.2
Hold window down button down for five secs extra after it has opened
Hold up part up for 5 secs after window has shut.
Repeat on passenger window
PS: You say that the roll over bar is not lifting with the switch. Is the warning light not on in the instrument cluster when driving. Does it light when you turn key to position '2'.
O
oscar wightman
will try to reset tonight...
also will check the rollbar light!
Cheers
