Sl55 2002 red battery light cluster battert drain
Tylerhayles1
sl55 amg 2002/2003
Hoping for a bit of luck may be a long shot but maybe someone has had the same problems will attach pictures
Getting the k57 battery isolation relay fault
Any ideas on where to start and what to do next, both battery seems to be ok heard alternator could play a part
secondly my cluster is causing a battery drain but cluster seems to function as normal, and have had it “repaired” also tried 2 different clusters and still getting a drain when i pull fuse 22 driver side 5amp the drain goes away
When I plug in the scanner its not even reading the cluster part number so kind of aint even recognising its on the system
Someone please help, finally getting to the end of the sl probably and these are doing my head in
mioba
Nottingham and Köln
do you know how to use a miltimeter to test the alternator, do that first.
Ditch the computer and fault reader as its not helping you
T
Tylerhayles1
sl55 amg 2002/2003
yeah i can do a test , what isit im exactly looking for figure wise on this?
I hear they are very specific on alternator and regulators, otherwise can throw up codes
mioba
Nottingham and Köln
engine running, vm across the terminals, should be getting about 13.4- 13.8v.
ie, should go up when engine running
