Sl55 amg wheels, tyres , problems
Tylerhayles1
sl55 amg 2002/2003
So where do i start basically curious
for those are a familiar and are tyre and wheel freaks, there is something known as rolling radius etc
The sl55 comes stock with
Front 255/40/18
Rear 285/35/18
some may have experienced some may have not that if you mess around with tyre ratios/profiles to much and dont keep within a certain limit you car can even go in limp mode and experience esp and transmission problems ( yes i done this with 35R on front and 40R on rear)
i always liked the idea of meatier tyres but has to be done in certain ways,
now i was going to do a suspension overhaul accumulators, valve block etc because im not to happy with my ride at the moment,
But now also looking into wheels and tyres more im concerned my set up also may be causint problems, ride quality, handling and even potentially transmission and power problems because of how the sensors relay for information.
so here goes
I have
255/40/19
275/40/19
now learning abot tyre ratios etc i have realised how ****** stupid this set up is and what it could potentially be doing to my car despite how good it looks
to think that if you car can go into limp mode with a bad set up, can a still bad set up but not as bad that it dont throw up codes, can it still be restricting your car without you knowing, my quest is could my set up actually be causing problems
Be nice to hear from experts or people who have actually dealt with this stuff
After checking ratio calculators
Im set on.
255/35/19 or 265/35/19
rear 295/30/19 or 285/30/19
That's still an odd setup.
On 19s it should be 245/35/19 front 285/30/19 rear.
Our own car is 245/40/19 front with 285/35/19 rear and it works perfectly.
flowrider
SL500 (R230)
Fronts should be 255/35R19 :)
Rears 285/30R19 is correct.
Another Malcolm mod then - narrower and taller on the front and just taller on the rear.
AMGeed
Poole, Dorset
1998/2001 W210 E280 x2 SOLD 2004 W211 E55 SOLD, 2014 E63 Biturbo SOLD .S204 C180K
I know its a different model but my E has 255x35x19 front and 285x30x19 rears
flowrider
SL500 (R230)
I wonder why Malcolm did that, the larger profile rears will make the car 4.3% faster than the speedometer reading.
More comfort from the higher profile.
Speedometer is deadly accurate now (against GPS).
T
Tylerhayles1
sl55 amg 2002/2003
Yeah i see the malcom 245 one,
so yeah think i will stick 255/35/19 front
And try 295/30/19 rear bit more grip then! And as this sit sayd its still well in tolerance and ok
Atleast i can safely say my existening set up is dreadful
Wider tyres don't mean more grip. It's a common wives tale.
The tyre footprint is the same for a given pressure as the air in the tyres is supporting the car. Narrow tyres therefore have long narrow foot print and wide tyres a short wide footprint but the surface area on the road is the same.
The only things wider tyres do is deform less on hard cornering (the difference between 285 and 295 is minimal), make more road noise and aquaplane easier.
T
Tylerhayles1
sl55 amg 2002/2003
Fair enough interesting stuff
Il stick with 285 to be safe
be interesting to know if my current set up is causing problems i may not know about
