SL55 legs
100%Bitch
Norfolk 'n' good
It would appear that I have a leak on my rear nearside leg.
What would be my best move? And I'm tired of hopping!
I've been given a quote of £1700 from the dealer and that includes £1077 for the leg which seems a tad steep.
They are easy to change helen, the worst part is the stripping out of all of the boot trim, I can do this now on a 230 in 1 hour now.
I thought that the rear strut was cheaper than the front at £850 plus vat MB charged me £100 labour to change it and I put the trim back again
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Dont you need to do the swirl on diags afterwards!!!! Heard your a cool mover Mal....
jib
jib
You only need to bleed that one leg jib, and you do that with all 4 wheels dangling. some rodeo the car for 10 mins to heat the fluid up before bleeding
It might be for you. :rolleyes:
You can save Helen by taking out the boot sliding cover, the rear inside trim and the side where the leak is, I can send you the instructions
Driven by AMG
Newton-Le-Willows
come on Malcolm get yourself over there and do the job for her. Surely you wouldn't turn down a job on Helens legs.
Sadly I charge more than MB for my services Dave:cool:
I'm much cheaper I only charge £45 p/h for my mechanical services & £65 for electrical.
I could never base my work on an hourly rate, and I charged what the job was worth, so my min charge was £45 for every thing that I did, but if they did not want it done , then no charge, I won be fixing 95% of the jobs in 10 mins max
pancholi
1996 SL 500 , 2003 CL55K, 2004 E320CDI
once the fluid is replaced, does the car need reprogramming via a STAR in regards to its height?
No the height is automatic, there should be no air in the system or it can sink on one corner where the air is
